- Kraton 8S
- Mojave
- Notorious
- Senton 6s
- Talion
O.K , so here is my problem , because I bought a Senton 6s slider , now I am moving an ESC/motor from car to car . If there is any of my RC's that I should put bigger electronics into , it should be the Mojave , right ????? It is a V1 , RTR with the BLX , not Spektrum . I def want to go HW 1650kv , but most I see everyone goes with the Max 6 . Why not a Max5 ? As I have a DBXL-E and SBR 2.0 that if for whatever reason want / need to change out the stock ESC , the Max 5 would be right at home in those big guys !!!
Is a Max 5 to big to waste into a Mojave ? Is it more dependable / have a better reputation over the Max 6 ? It is only about a $70 difference . The one thing I like about the Mo is you can pull the throttle 100% , and it takes off !!! I actually DON'T want it to be a wheelie machine , so adjust in the pinion and/or punch to try and resist it doing that ?
FWIW , I have a HW Max5 / 1100kv in my K8S , and it runs flawless/ cool !!!Thanks for the input !!
Or ,..... put it in my Talion ????
