Scottcraig1978
- Typhon 6s
I noticed that the fan on my ESC wasn't on during my last run. Isn't it supposed to run continuously? Thanks guys.
Any reason you know of that it would stop? I'm almost positive it is always on from the moment you turn it on.I wanna say yes it’s supposed to run all the time. Prevents it from overheating
Maybe it took a poop?Any reason you know of that it would stop? I'm almost positive it is always on from the moment you turn it on.
The buggy is new... Third run. ?Maybe it took a poop?
Oh. Maybe wait for others to chime in. To me that’s a sign of a bad fan.The buggy is new... Third run. ?
I just checked for debris, all good. Although feels loose, it is in fact still plugged in. Does it happen to turn off at the end of the battery charge?Make sure there’s no debris stuck in between the bottom of the fan and the heatsink that would keep it from turning. While it’s apart make sure it didn’t pull one or both of the wires from the back of the fan, or unplug itself from the port, which happens from time to time.
