ESC fan replacement
villyn666
Woodbridge va
  1. Felony
The stock esc in my felony 6s seems to heat up quick with the stock fan set up
Any suggestions for a plug and play esc fan that will cool the esc better than the stock.
Appreciate your response
Problem isn’t the fan.
I’d tend to agree. I’ve found on my street rippers with Spektrum systems that too big of a pinion heatsink up the motor too much, and too high of a timing selection heats the ESC up. Unless the batteries are just terrible, low-c junk, that can raise ESC temps, too.
When the system is dialed in well I’ve never had a Spektrum ESC overheat at all with the stock fan.
27 pinion, the one that came with the felony as speed option
That will definitely get things a bit hotter..also depends on what kind of a basher are you???..are you trigger finger happy all the time???? 🤷 many things can factor into your electronics heating fast .
I would suggest if you don't want to lower your pinion down by a few teeth ,then let your electronics cool off by giving them a break every so often
And keeping a close eye on your temps ..as mentioned a better fan is recommended..double fans on the motor .bigger fan on the esc ,you can double up on them also if you like ..
Thanks for the feedback
I’m powered by two 3s Yowoo 150c 5500mah they seem to be pretty good for speed run. I’m thinking of two HRB 120c 7200mah as back up
Ok I’ll update the timing, any set number?
I changed my diff fluid to 500k if that is the blinker fluid
Thanks
I have a twister fan on the motor and yeah a I’m lil finger happy 😃. I get about 10-12 until it stops on me and I let it cool. I check batteries too make sure they haven’t hit the 3.7 limit. Then I get in some more runs.
I’ll change the esc fan and timing
Thanks again for the $.02 👍🏾
Thanks
I gave you $.05 😂 you owe me three cents plz
Thanks
Let it cool before thermal cut off happens.i toasted a esc that way.now you owe me another .02 cents 😂
