How do you drive the Typhon? The MMX8S can be ran on 6S but doesn’t have screw tabs. You would have to use double sided tape or velcro.
used to bash it and do big air jumps but got tired of stuff breaking and having to fix/repair parts. now it’s just speed runs and/or ripping around on pavement.How do you drive the Typhon? The MMX8S can be ran on 6S but doesn’t have screw tabs. You would have to use double sided tape or velcro.
Any of the Castle then. MM2, MMX8S, or XLXused to bash it and do big air jumps but got tired of stuff breaking and having to fix/repair parts. now it’s just speed runs and/or ripping around on pavement.
MMX8S if you can get one.xlx won’t fit in original location. i know it could be far fetched but i’d like something i could put where the original blx185 is located. that’s why i looking towards the max6, are any of the castles similar dimensions as the blx185? i want to stay 6s as it’s very difficult to impossible to fit 2 batteries under the body on a typhon unless they’re lower Mah.
i was going to go with the TP power 4070 2900KV but it won’t fit without either modding the mounting location of the motor/center diff mounts or transferring everything onto a kraton chassis(don’t really want to do either) so now i’m also looking for something in the realm of that motor, i know nothing will be very comparable but something in the same zip code, wonder if TP has something with a smaller can. ?
Both the MMX8S and MM2 Retro would fit the bill.xlx won’t fit in original location. i know it could be far fetched but i’d like something i could put where the original blx185 is located. that’s why i looking towards the max6, are any of the castles similar dimensions as the blx185? i want to stay 6s as it’s very difficult to impossible to fit 2 batteries under the body on a typhon unless they’re lower Mah.
