The 3m stuff is the same way it comes off cleanly without residue, I have broken a few receiver cases trying to remove them.I use Gorilla clear double-sided tape that is rated to hold 15 pounds. I have never had an issue with it coming loose: when I've had to remove an ESC for some reason, I've had to use a fair amount of force to get it to let go.
https://www.walmart.com/ip/Gorilla-Tough-Clear-Double-Sided-Mounting-Tape-60-Roll/100188691?wmlspartner=wlpa&selectedSellerId=0&http://clickserve.dartsearch.net/link/click?lid=92700060762254883&ds_s_kwgid=58700006715445296&ds_s_inventory_feed_id=97700000003583668&ds_a_cid=654818135&ds_a_caid=13956209185&ds_a_agid=126452889113&ds_a_lid=pla-1392082700544&ds_a_cid=116919406&ds_a_caid=361575031&ds_a_agid=1200667322826314&ds_a_fiid=&ds_a_lid=pla-4578641339573147&&ds_e_adid=&ds_e_matchtype=search&ds_e_device=c&ds_e_network=o&ds_e_product_group_id=4578641339573147&ds_e_product_id=100188691_0&ds_e_product_merchant_id=27449&ds_e_product_country=US&ds_e_product_language=EN&ds_e_product_channel=Online&ds_e_product_store_id=&ds_url_v=2&ds_dest_url=?adid=2222222242031946843&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=&wl4=pla-4578641339573147&wl5=&wl6=&wl7=&wl8={aceid}&wl9=&wl10=27449&wl11=Online&wl12=100188691_0&wl13=&veh=sem_LIA&msclkid=48b141478b1e11a6f88b22efb9692610&gclid=48b141478b1e11a6f88b22efb9692610&gclsrc=3p.ds
Unlike many double-sided tapes, this Gorilla tape comes off cleanly without leaving a residue or part of the tape.
I have had issues with the 3M double-sided tape that comes with Hobbywing ESCs, and I avoid 3M products for that reason.The 3m stuff is the same way it comes off cleanly without residue, I have broken a few receiver cases trying to remove them.
The automotive stuff is a bit different than the stuff that comes with the Hobbywing escs.I have had issues with the 3M double-sided tape that comes with Hobbywing ESCs, and I avoid 3M products for that reason.
I had a similar issue with the Gorilla tape on receivers. On the Radiolink R6F receivers, the bind button is situated in an indentation on the end of the receiver. If you forget to bind the receiver before you install it, you have to remove the receiver to bind it. It's a PITA to remove it when using Gorilla tape. Ask me how I know.![]()
The standard 3M tape that comes with ESC's and the like is only ok for Mounting Rx's in the Box. It is light duty stuff. Also, 3M tape does get old depending how long its been sitting around. It can dry out. Been there. 3M tape should be kept is a Sealed bag for storage. Stuffs not cheap.I have had issues with the 3M double-sided tape that comes with Hobbywing ESCs, and I avoid 3M products for that reason.
For ESC's, I always use 3M Automotive grade tape. It holds well in very cold weather and is waterproof. Having worked in Autobody repair, this is the best. 3M is the best out there as a brand. And 3M makes many different grades of tape FWIW.
I use a heat gun to warm up the tape first before installing it.. Press and hold for half a minute, and like @slick2500 stated, 3M tape does fully cure in 24 hours. Needs some time.
I never had a problem removing it either.
At the autobody shop when "renewing" old door mouldings for instance, I could remove the old tape with a heat gun. and some spirits/solvent. Piano wire slices the tape neatly to separate it, if need be.
Yup that's why I use it, if it's good enough to hold the trim, molding and emblems on real cars it should be just fine for holding an esc in place.3M is what all the Car Mfr's use at the factory.
Just don't use it when it is Cold and surface is dirty or oily or paint has wax on it.. It doesn' work at all. Just a waste of tape.
Why I always use a heat gun to warm up the tape. It activates better.
