RC617
Background: So I'm still very new to RC cars and I have been looking into what is the target battery voltage when removed from my RC (Kraton 6S V5), after LVC is reached. From the few runs I have under my belt batteries measure at ~3.8##V. From looking online it looks like 3.7V is maybe the normal target. This being the case I was looking if I needed to tweak my LVC, however looking at the Kraton manual and the following thread, it appears this cannot be done:
https://www.arrmaforum.com/threads/low-voltage-cut-off-on-the-v5-kraton.30217/
My confusion is the Firma 150A ESC manual shows that there is a LVC setting. So is the Kraton V5 using a modified version of the Firma 150A ESC and not the standard consumer version? Also, it seems based on what I've read that the default LVC of 3.0V/cell is low (maybe I'm missing something).
I guess ultimately what I'm trying to figure out is:
1)Is 3.8##V post run normal or am I leaving run time on the table?
2)If 3.8V is higher than necessary is there anything I can due to adjust this? From the linked thread I know there are low voltage alarms, but this seems to only be a solution if the LVC is too Low not if it is too high.
