ESC REBRAND CONVERSION GUIDE
Is it right for a forum moderator to be able to edit anything you say without a notice to the public
  • Total voters
  • This poll will close: .
Peeeenuuutt
Senton
If anyone has any others, please chip in. Anything with nothing next to it means it is completely identical other than exterior features. For the abbreviations I used:
MMM= Mamba Monster Original
MM2= Mamba Monster 2
MMP= Mamba Max Pro
F310C= Castle Mamba Monster series made before 2013
F360C= Castle Mamba Monster series made from 2013 and up, not including the Mamba Monster X.
  • Traxxas MXL-6s= Castle MM2 (F360C)
  • Traxxas ET-3s= Castle MMP (WITH ONLY 3S LIPO CAPABILITY UNTIL HACKED, THEN YOU CAN USE 6S)
  • HPI Blur=Castle MMM (WITH LIMITED PROGRAMMABILITY) (F310/F360C)
  • HPI ELC-6s= Castle MM2 (LIMITED PROGRAMMING) (F360C)
  • HPI Rage= Hobbywing8BL-120
  • HPI ELH-6s=Hobbywing8BL-150
  • HPI Q-Base=Castle MMP (LIMITED PROGRAMMING)
  • Axial AE= Castle Sidewinder
  • Axial AE-2= Castle Sidewinder 2
  • Axial AE-3= Castle Sidewinder 3
  • Axial AE-4= Castle Sidewinder 8th
  • Arrma BLX-200= Hobbywing Max8 (LIMITED PROGRAMMING)
  • Arrma BLX-185= Hobbywing 8BL-150 (LIMITED PROGRAMMING)
  • Arrma BLX-100= Hobbywing Max10 (LIMITED PROGRAMMING)
  • Hexfly HEX 8= Hobbywing Max8 (LIMITED PROGRAMMING)
  • Hexfly Hex6= Hobbywing Max6 (SOME LIMITED TO 6S ONLY, BOTH LIMITED PROGRAMMING)
  • Hexfly Hex10= Hobbywing Max10 SCT (LIMITED PROGRAMMING)
  • Dynamite Fuze-150A= Hobbywing 8BL-150
  • Dynamite Fuze 160A= Hobbywing Max6
  • Dynamite Fuze 130A= Hobbywing SC8
  • Dynamite Fuze 90A= Castle Sidewinder 8th
  • Thunder Tiger BLC-150C= Hobbywing EzRun 150a (LIMITED PROGRAMMING)
  • Thunder Tiger BLC- 80C= Hobbywing EzRun 80a (LIMITED PROGRAMMING)
  • Reedy SC300-BL- Hobbywing Quicrun 16BL30. (LIMITED PROGRAMMING)
  • Reedy SC600-BL- Hobbywing Quicrun 10BL60. (LIMITED PROGRAMMING)
  • Leopard BL5- Hobbywing Max5 (LIMITED PROGRAMMING)
Any other labelings are appreciated. This took awhile, hopefully it’s a point of reference for people. The arrma esc’s also seem to be detuned along with the program limitation but the detune is most likely part of how they changed the programming, therefore will not be mentioned. Arrma and Traxxas are the only ones who actually changed the programming, the others just don’t have access to some minor features.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
Kraton, Typhon, 4x4-Mega
Dynamite Fuse 130a is a HW SC8.
And the BLX100 is not 4s capable, but the MAX10sct is.
Peeeenuuutt
Senton
Will add that one! Let me put in the 130a and modify the blx100’s description. (Didn’t even know dynamite made a 130a)
Now that you mention that, are you sure the blx 100 is a max10 SCT and not a regular max10 (2s-3s one)? The build looks like a max10 and i think it’s that but everyone’s saying it’s a max10 SCT so I guess I’ll go with everyone else’s saying.
You know what, everyone’s wrong, it’s definitely a max10 not an sct because it looks so much more like a max10, compare the blx 185 to the 8BL-150 and then compare the blx 185 to the max10, clearly it’s the scaled down version, if it was the max-10SCT it’d look like a scaled down BLX200. That said, updated it to a max10. That explains the heat being a little high on 3s and the non 4s capability.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
I wonder about that too. The standard Max 10 is a 60a esc, though, which seems a bit light for a 3660 motor. But then, maybe that is why there are so many failures.
Gt rubicon
Northern California
Outcast
This is very useful! Thank you for the time and effort spent to help those of us who have no clue navigate the purchase of the life blood of our hobby!
Peeeenuuutt
Senton
Precisely what I was thinking. Max 10 SCT’s are very reliable, and so are max10’s, but if you put them in a setup pushing their limit they do start to show an ugly side, and in arrma’s 3s line a max10 SCT wouldn’t be stressed at all, meaning no failures or heat issues, which is not the case, which is why my thinking is that it is a normal max10.
olds97_lss
ArrmaForum Fan
What's a "castle MMP"?
Jeckler
Kraton
I wonder what's different about the Fuze 150 to warrant a $60+ increase over the HW 8bl150.
And I can confirm the ET-3S to MMP hack, though it doesn't like running anything more than 4S in my experience. I use one in my SCX10 Dingo.
Peeeenuuutt
Senton
Well to be fair that's to be expected, the MMP doesn't like more than 4s either. It's a 10TH scale esc.
Peeeenuuutt
Senton
Added thunder tiger esc's.
I would expand the thread with a motor segment, but really that's a common misconception that "this is a rebranded version of this" because 99% of the time it is NOT. In most cases, it's quality is worse and the magnets aren't as strong (Traxxas 2200 vs castle 2200 for example)
Added castle designation F-series numbers to avoid confusion with what version of mamba monster 2 and mamba monster 1 each is.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
Reedy SC300-BL - Hobbywing Quicrun 16BL30.
Reedy SC600-BL - Hobbywing Quicrun 10BL60.
Reedy SC800-BL - Hobbywing Quicrun ?????
Reedy SC1000-BL - Hobbywing Quicrun ?????
These have limited programming compared to the Hobbywing counterparts.
Peeeenuuutt
Senton
Added the first 2 esc’s, after confirmation I will add the other 2. Thanks again.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
The other 2 might not be rebrands but custom made escs kind of like the Redcat Hobbywing escs.
Are we sure the BLX100 is not a neutered down Max10 SCT?
Peeeenuuutt
Senton
Yup. I am definitely sure. The max10 SCT would be so overly qualified in those 3s vehicles people would be praising those trucks out the ass for a bulletproof esc. That is not the case. Also the visual models don’t match up at all. It’s definitely, 100%, a max10.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
Alright I just find it more likely that they neutered down a Max10 SCT, like the Max10 SCT rtr from Redcat, than that they somehow managed to turn a 80a esc into a 100a esc just to neutered it down again.
Peeeenuuutt
Senton
Did you listen to any of the times I explained in depth with huge paragraphs to people that esc amp ratings are completely useless?
Just because they change it from 80 to 100 doesn’t mean they changed anything inside to help it handle more amps. Nobody does that. Takes too much time and money. They probably just rated it higher so people think it can actually handle the motor it’s paired to for a long time.
And for that reason it’s a max10. Let’s say it is a max10 SCT for a second. If they “neutered” it down, it’d be slower and stuff, but that’s it. No extra heat or nothing. It wouldn’t make a worse performing esc that can’t handle enough amps. Let’s be honest, do you really think they went in there and pulled out a few FET’s and swap the caps for worse ones so the esc would perform this much worse than a max10 SCT? Or do you think they just used a max10 with no modifications other than throttle programming.
And let’s say they did do that to a max10 SCT (pull out the stuff and make it crappy) if it’s underperforming and acting exactly like a max10 would in the situation it’s placed in, id call it a max10 anyway lol
E Electronics 1
B Electronics 8
C Electronics 1
Y Electronics 2
Similar threads
