- Germany
- Felony
- Fireteam
- Infraction
- Kraton EXB
- Outcast 4s
- Vorteks
Ok, that screenshot is really helpful. So I'm pretty sure the Castle Link doesn't recognise the ESC because the SW is newer than the old Castle Link 3.4. If you connect it to the current Castle Link or the 3.56 are you able to downgrade the firmware to anything lower than your current one on the ESC? If so you could downgrade it and try to reconnect it and see if it works then (on V3.4). Also, can you check if the Sidewinder 8th is available in the Castle Link 3.4. I'm currently not able to install Castle Link and therefore I can't check if the Sidewinder 8th was released before or after the Castle Link 3.4. You can check it quite easily, just go into Demo Mode and see if there is a Sidewinder 8th listed. If so, we can definitely make your Dynamite 90A a true Castle ESC.View attachment 56174
An error code appears as in the picture.
For your information, I use the firmware on the link above
The esc of Traxxas xo1 is mamba monster2
The original version was successful.
What do you mean with the XO-1 ESC? Did you convert one to a MM2 successfully?
