Afro Samurai
awesome stuff...for when your esc liberates itself when the old tape gets dirty...
http://www.mcmaster.com/#7626A237
yeah...I have had mixed results with velcro ...seems once it got sandy...and me being too lazy to clean it out...I got packed up and ruined it's holding power...
may start using the interlocking mushroom type velcro this next go round and give that a try...
http://www.mcmaster.com/#96055k23/=13n1vns
If you are not in a hurry to use the truck and would like something durable. I would recommend 3M tape and put silicone around the edges, dirt and water won't get into the tape. This works well for me.
Guys - I went to home depot to get 10-40 oil and in the same section -I picked up two other spray cans. One is Silicone spray and the other is a rust protectant for screws - when I get home I will add pics of these but they work great.Before I discovered VHB tape, I mounted my electronics with a blob of RTV silicon. I even mounted my steering servos on pan cars with the stuff. Never had it fail, so long as I waited 24-48 hours to use it. It was a booger to get loose, though. Cut it loose with dental floss, then razor blade the chassis and electronic smooth...
Ahh,, Memories...![]()
I'm talking about silicone adhesives that you use for your tub, aquariums and bathrooms.
