There are not new. But yes newer than the Onyx batteriesHow new are the SMC batteries? Sometimes new batteries can give short runs until they get a few charges in them I've noticed.
Maybe because the c rating on the SMC batteries is 90 and 50 on the Onyx.I noticed the BLX esc cuts off around 3.42, even though it's setting is 3.2. Someone mentioned in another thread, it's likely because there is a stronger draw on these 6s beasts, so the esc reads a lower voltage for an instant, and cuts out. Once you release the trigger, the batteries regain a tiny amount of voltage, thus the higher than specified cut off numbers. 3.8 sounds a little high, but I would prefer around 3.7 if I was able to set my own cut off.
