- Woking, UK
- BigRock 4x4
- Kraton EXB
- Notorious
- Senton 3s
So this happened, wire has broken where the solder stops where it is most at risk of fatigue. Seems the weight of the capacitors on the cable flapping around is bad - who would have thought! and the wire clips Arrma put by the drive shaft are useless of course.
So now I have this, which will hopefully stop it happening again. When I get some appropriate wire I might lengthen them so I can strap the capacitors to the dirt guard at the front.
Others might like to look at preventative measures before it happens.
