Every Diff ever...
Discussion in 'Chassis & Drivetrain' started by ThatDrewGuy, Jul 8, 2018.
  1. ThatDrewGuy
    ThatDrewGuy Premium Member!
    Apr 18, 2018
    113
    62
    Chicago Area
    Arrma RC's:
    Granite, Kraton, Talion, Typhon
    So this is what every diff I have ever opened right out of the box. This is why we go through our “RTR” vehicles.
    WoodiE likes this.
  2. slick2500
    slick2500 Well-Known Member
    Aug 21, 2017
    1,442
    530
    Rapid City, SD
    Arrma RC's:
    Outcast
    Well as we all know RTR means ready to rebuild.
    Doughboyoutcast, WoodiE and RxMonkey like this.
  3. BattleShrink
    BattleShrink Well-Known Member
    Mar 30, 2018
    28
    10
    Arrma RC's:
    Kraton, 4x4-Mega
    Just got a kraton, drove a few packs through it, I've been putting it off cause I was using 4s. I guess I'll get in there, thanks for the reminder.
  4. Jerry-rigged
    Jerry-rigged Premium Member!
    Premium Member Excellence Award
    Apr 27, 2016
    1,794
    979
    Texas, Baby!
    Arrma RC's:
    Kraton, Typhon, 4x4-Mega
    Actually, that one looks OK. The fluid is covering the cross pins, which is correct. You don't want it full to the top.
    But yeah, RTR = Run at your own Risk. Ready to Rebuild. Rebuild before Running. But at least Arrma uses threadlocker... LOL
    Coopsonthefarm likes this.
  5. RxMonkey
    RxMonkey Well-Known Member
    Apr 10, 2018
    104
    146
    Virginia
    Arrma RC's:
    Kraton, Outcast, Senton
    An Arrma kit. Still costs $500. No electronics. But a detailed assembly book, aluminum chassis braces/servo mount, necessary diff shims and a clear body to paint yourself. *wakes up to alarm* ahhh damn it was a dream.
    blindy likes this.
  6. WTF MIKE
    WTF MIKE Well-Known Member
    May 16, 2018
    57
    Arrma RC's:
    Outcast
    A bit off topic. I somehow managed to chew up my out put shaft that the dog bone goes into. So my question is do I have to buy a complete diff set in order to get just the out put shaft? I’m not sure if it’s even called an out put shaft lol
  7. Jerry-rigged
    Apr 27, 2016
    1,794
    979
    Texas, Baby!
    Arrma RC's:
    jonUF02 and slick2500 like this.
  8. 2fast4u
    2fast4u Well-Known Member
    Sep 12, 2017
    87
    42
    Delaware, Ohio
    Arrma RC's:
    Kraton
    All the diff outputs are (AR 310439). Outcast, Kraton, Talion, Typhon. I'd probably replace the pins (AR 310440) and O rings (AR 716011) while you're there. And shim it if it's never been done.
  9. WTF MIKE
    May 16, 2018
    57
    Arrma RC's:
    Outcast
    Thank you. That’s all been done less than a month ago
  10. WoodiE
    WoodiE Kind of good admin
    Staff Member
    May 14, 2015
    2,896
    1,897
    Lexington, KY
    True that!
  11. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    374
    115
  12. ThatDrewGuy
    Apr 18, 2018
    113
    62
    Chicago Area
    Arrma RC's:
    $600 for a kit that needs all the important stuff.... I love Arrma:mooning:
  13. Coopsonthefarm
    Coopsonthefarm Well-Known Member
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
    Why do you not want to fill the diff all the way up? And if I’ve done so already should I immediately drain them a bit or will it be ok till my next diff mantanance? Thanks
  14. olds97_lss
    Dec 14, 2016
    374
    115
    When you put the top gear on, it will push out the oil that doesn't fit. I usually fill to the top of the cross bars, level with them. @ThatDrewGuy 's looks like it's to the bottom of the cross bar.
  15. slick2500
    Aug 21, 2017
    1,442
    530
    Rapid City, SD
    Arrma RC's:
    Outcast
    Item(s)
    Tower Hobbies Super Savers Club discount ftw.
    $ 599.99
    Shipping (Standard Shipping)
    Waived
    Savings Applied
    Coupon Codes
    -$ 84.00
    Total
    $ 515.99
  16. Coopsonthefarm
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
    Got you. Thanks, makes sense
  17. Jerry-rigged
    Apr 27, 2016
    1,794
    979
    Texas, Baby!
    Arrma RC's:
    I would not tear it down just to remove a bit of fluid, personally.
    As for why not to fill them all the way up, across many forums, I see arguments for and against leaving some air in the diffs. I have no clue what side of that argument is correct, so I defer to every mfrg build instruction that I have seen - they all say to fill above the cross pins, but leave an air gap. Some show a smaller gap than others, but it is there in every build instruction I have seen. For the diff in the OP, maybe it could use another mm or 2 of oil, but most of my RTR's that I have opened barely have enough to coat the gears... So for a RTR, that OP diff is pretty good. :)
    Edit - the Arrma version - filled above the crosspins, but not fully covering the gears. This is from the BLX6s V2 manual -
    #17 Jerry-rigged, Jul 12, 2018 at 7:55 AM
  18. 2fast4u
    Sep 12, 2017
    87
    42
    Delaware, Ohio
    Arrma RC's:
    Kraton
    By the time the other sun gear is in there, I would call that full.
  19. Coopsonthefarm
    Apr 28, 2018
    19
    36
    Kauai
    Arrma RC's:
    Outcast, Talion
    Thanks for the info! Well, mine are shimmed and filled to the brim. Gunna have the first big bash tomorrow on 6s. I’ll keep the forum informed if the diffs experience any negative side effects from being topped off.
  20. Jerry-rigged
    Apr 27, 2016
    1,794
    979
    Texas, Baby!
    Arrma RC's:
    Lots of people run with diffs 100% full, so don't expect you will have any issue due to that . :thumbsup
  • Welcome to Arrma Forum
  • Disclaimer
