nrrtrains
this is one of the best tools you can have in your tool box , cheep but wort every penny . it is a servo tester . i have been using them for years .
Yeah, I love mine. Have learned to test servos prior to installing. Just cause you don’t think it’s needed doesn’t mean others need to share your assumptionsNo, this is not important in RC Cars. No one has these for RC Cars. I have never seen anyone
We don't need more than 180degrees servos max
And we use only one or max 2 servos.
This is only for Robot builders with very cheap 20-200pc servo bulk installs, and where you may need servos that turns 200degrees +
You can catch a bad/weak servo prior to install for one. You can test an existing servo to confirm its working properly as well. Yet another nice tidbit I’ve learned from SrC over the last 14 months or so.Why? I've never used one and don't know what I'm missing.
Ok cool good for you. Between spelling and sentence format I’ll avoid arguing further. Suddenly got a headache.I don't understund stil
Why buy this to RC Car ?
You test servo from your receiver before install, also center the servo this way.
No problems.
I don't need a tool for this like a servo tester at all.
And i have more than 100 rc cars total in my life.
Have buy better servos to many rtr cars and so on.
Never had any servo that fails. Had more than 150 different Servos.
They are quality controlled from factory. Always good
This TOOL (servo tester) is for robot guys, and maybe to guys who buy bulk poor quality cheap servos, and maybe to airplanes, the guys who use 6-10 servos in one model
then this tool makes sence.
In RC Cars no i don't think EVERY ONE needs this tool, not at all actually
Why would we?
the servo checker is for checking the servo after you buy it , put it in auto and it will let the servo run as long as you want . if a servo is going too fail it will usually happen in the first 5 minutes not counting striping gears from bashing or hitting an object . i learned from flying planes to test every servo i install in any of my planes because in the air is not like on the road or track if a servo fails your plane is going in and the outcome is not pretty .But when you need to check a servo and don't have the rest of the system in place it's a great tool.
