That is lovely @Evil-T . Great job on that by the painter.
Little tip just in case it helps you is that when you come to fitting the rubber tethers for the "R" clips use a hair dryer to heat up the rubber nice and warm. Then pass the rubber mushroom/wedge end (not sure what to call it) through the body using a pair of flat nose pliers on the inside to pull it into position. Hope that helps.
