ibocain23
Was going to go with M2C but seeing how cheap I can get an EXB chassis for my K6S V5 via JRC I’m thinking is the M2C worth the extra 100$. Any thoughts?
If the RTR is a 1 and the M2C is a 10, IMO the EXB is a 2.I have this question too. On a scale of 1-10, with 1 being stock, 10 M2C, where would EXB score?
I'd think that if you don't bash extreme, bending a stock chassis back every time and replacing it every so often should be find, though I don't have experience
IT's cheaper but i don't think the exb is 7075Was going to go with M2C but seeing how cheap I can get an EXB chassis for my K6S V5 via JRC I’m thinking is the M2C worth the extra 100$. Any thoughts?
That would be $90 and a lot heavier. It wouldn't be worth itHave any tried two EXB chassis at once? With 3mm longer screws.
The car will be heavier but if it mounts ok maybe a ok setup and if you get the two EXB chassis for cheap price.
I use M2C on my Talion and Kraton. And a bashbar on my Notorious.
If you have some tools I believe a bashbar could be made easy.
Its just a metal bar with a few holes. And a small bend in the front.
But I did buy the bashbar.
That’s ironic because my Typhon EXB chassis bent so often I threw it away. I had intentions of running it as a street car but ended up stretching it with a Mojave EXB chassis instead. So for street use, I think the EXB is fine, as would be the RTR for that matter. However I would want M2C or any other real 7075 chassis.It all depends if we are talking a SWB or LWB chassis. If LWB, just get an M2C.
SWB EXB are fine and for the price works. I never bent my Noto chassis. SWB ( identical part as the Typhon Chassis) Been through so many LWB Stockers on my Kraton. Just as refernce. LWB, most any Arrma chassis, EXB or Stocker V5 or V4's will bend and twist.
