Hector_Fisher
I've assembled my diff multi different times in different configurations trying to diagnose some binding. The one way I can definitely stop the binding is to remove the input washer/shim. In fact, i can add two shims on the ring gear and get basically perfect mesh, but only when the input is not shimmed. Not sure whether its the gear teeth binding or the input gear binding on the plastic diff case. So is the input shim required?
Came from the factory with one. So i was wondering if they perhaps help distribute load amongst the gear teeth onto the bearing racing or something. But exploded view doesn't show one.
