Kraton EXB Max5 and Hobbystar 56112 980kv
sanara.kenshin
Military Veteran
LB, CA
  1. Kraton 8S
  3. Notorious
  4. Outcast 8s
Finally got the k8s exb out. Its my first 1/5 scale after 3 months in the hobby. Its my new favorite truck. My set up is Max5, Hobbystar 56112 980kv, 32t pinion and 39t spur. So much power I can even use whole throttle range. I need to find a bigger space to launch it. This thing just needs to much room to run.
https://youtube.com/shorts/6wTfRvsEdIM
Thanks the same set up I run. I run the proline mx43s for tires.
How do you fellers like the 980kv? what gears ?
I'm trying the 32t as well with 39spur
Im actually surprise how good this set up is. I just follow Rich D’s setup. Esc setting are stock. Punch setting is at 3. Next is just tune the suspension and probably change to heavier diff oil for F&R.
Yeah I would...make sure you get the diff screws good and tight..I have have a few differential where the screws came undone and took out the dows and the gears ⚙
Yeah I would...make sure you get the diff screws good and tight..I have have a few differential where the screws came undone and took out the dows and the gears ⚙ View attachment 133969View attachment 133970
Thanks for the tip. I will be checking on it. I was just couldnt wait to try it out. Its my first 1/5. Rich said on his video that the diffs were filled good from factory. Im sure it will he okay for a weekend run. Looks like Arrma has been improving on QC.
I just ordered the 980kv and max5. went with 32t, 35t, and 39t pinions. It's been a few months. How are you guys liking the setups. whats been top speed?
Running the lepoard 200a (max5) and same hobbystar motor with 39/39 running proline mashers I topped out at 59.6. It wasn’t quite maxed out yet
I pulled my trans and diffs. Apart. ( everything was loose after about 6 packs). Front and rear diff fluid very thin. Changed to aluminum diff housing front and rear stainless bolts and 2m diff gel. Trans seemed a little thicker cleaned it all out put in 25m and stainless steel bolts. Loctited everything also upgraded trans housing to aluminum…. Truck. Handles so much better.
Side note I just put a TP 960 in my Cexb ( hand built from scratch). They are a 50k Rpm motor. Haven’t done a speed run yet but it felt like another 10–15mph.
Do you have any heat issues?
