Would fit just fineboought exb mojave and wondering how a spektrum 160a esc and a 4685 1250kv motor fits
thanks! need a new motor mount or would stock one work? and would the esc mount work as well or need to stick it down with something?Would fit just fine
Motor should mount to stock just fine. ESC should screw right on too.thanks! need a new motor mount or would stock one work? and would the esc mount work as well or need to stick it down with something?
thank you for the advice! I'll post a update pic once I get everything put togetherMotor should mount to stock just fine. ESC should screw right on too.
Did ya get er done I’ve got the same set up but the esc mounts aren’t even close I think I’ll drillthank you for the advice! I'll post a update pic once I get everything put together
bro honestly, I just ziptied it inDid ya get er done I’ve got the same set up but the esc mounts aren’t even close I think I’ll drill
My own mountings and was wondering how you did yours
