dc4_kev
- Granite
Hi everyone!
I wanted to jump on here and kinda hear everyone's input on my current situation. Got my Kraton EXB during the black friday sale 2021 and threw in a HW Max6 1650kv combo along with a 20 tooth pinion gear. I originally ran it on a 15 tooth pinion gear but decided to up it a notch. Didn't seem to end well because after just some punches on low cut grass to do wheelies, I have seem to lost power to the rear. A crunching noise started to happen to which I took apart the rear diff to see the input and ring gear are fine. Upon further inspection, in the diff I found the fluid to be very metallic and gritty so my suspicion is the internal gears of the diff have been stripped and no longer meshing. I've included some pictures of my findings.
I don't believe this a common issues as I've only seen threads posted on here about the input and ring gear mesh so my question is can I warranty this with Horizon? You can see some damage to a few of the teeth and when touching them, they feel sharp as if they were sheared down but its not very obvious what the issue could be here.
