So, buying this (ARA106053) https://www.horizonhobby.de/en_DE/p...ller-speed-monster-truck-black/ARA106053.html
i don't have to open the diffs and install shims or anything else, except the LSD items in case i want limited slip from any of the diffs?
The Kraton EXB comes with the diff plates in all three differentials. The Front and Middle are set up in the x3 configuration (most limited slip) while the rear is set up in the x1 configuration (least limited slip). You can replace the plates with shims from the shim kit (ARA311094) to run any of the diffs in an open configuration.
That being said, you should always open up a new diff to check shimming and fluid levels.
