- Germany
- Felony
- Fireteam
- Infraction
- Kraton EXB
- Outcast 4s
- Vorteks
Haha I just guess it from my experience. But I would say around 65mph with that pinion. Just keep an eye on the temps. My motor runs quite hot with a 20t. CNHL batteries are great. I need to get some soon. I use some HobbyStar batteries in mine. They do the job but a month ago it was super cold and I went out for a bash and used my Graphene Panthers 5000mah, which are basically the same as the CNHL and the run-time was so good and they still packed some punch even in those temperatures. There can be a huge difference between Lipos.How do you work out the potential top speed if you run the 1650 with the 50 spur and 23 pinion
I’m also running CHNL 100 c constant with 200c bursts (they definitely have some kick!), first time I used the batteries I hit the throttle to its usual spot to pull away and it ended up on its roof, no #%$€!!!!!
