Kraton EXB V2 - Seems slow , No Brake / Reverse!
GTS_MAD
Hi All,
Haven't ran my EXB yet but yesterday I went to run in Plugged in a fully charged Lipo , But the car doesn't seem to go to full throttle , and also has no reverse or brake?
I have tried doing the calibration but no success.
Can anyone help me?
Did you do the calibration on both the transmitter (making sure all trims setting are 100% or neutral) AND esc?
I did the calibration where I held the set button down on the ESC , Then full throttle pressed set etc etc and ran through until completion.
Kind if sounds like it isn't set to 100%. On the stock transmitter If it's set to 75 or 50% you don't get reverse for whatever reason.......if I remember correctly.
Calibration wouldn’t work properly if the transmitter wasn’t set to 100%.
I agree with what the other members said
- Ensure all endpoints are set to 0 and transmitter throttle limit is set to 100
- Recalibrate the ESC
- Walk thru all the ESC programming menu items to make sure the parameters are correct
I didn't even think about that. If it was on 75 or 50 then no reverse and you couldn't finish the calibration.
Hmmmm. Then the only other thing I could think of is settings on the esc itself but to be honest I don't know a ton about the spektrum esc. I've been swapping them out with hobbywing stuff.
As redundant as they seem, I'd say follow the manual instructions. However, since I hate reading instructions myself, I don't know if they specifically outline setting up the transmitter first, LOL. Good luck.
