D-rek07
Hello everyone first time poster on here so cut me some slack. I've done a lot of research on shimming the diffs. I've noticed people putting a shim in between the bearing and the diff case to push the ring gear closer to the pinion gear. However obviously this is limited by the other side of the diff case so adding more shims will just bend the plastic out as opposed to making a tighter fit between the ring gear and pinion gear. I broke a tooth off of the pinion gear and put a flat spot on two or three of the teeth on the ring gear. How does any of the shimming ideas prevent this from happening again?
