- Colorado
- Infraction
- Limitless
- Outcast 6s
- Typhon 6s
This combo by chance plug and play or are the esc/motor wire bullet connectors different sizes??
I’ve always liked the 1 more as well because it runs a tiny bit cooler than the 2 due to not having the heat insulating water proofing, along with no voltage limiting or current limiting, so you can run 8s (also been done on YouTube) but the 2 can just be reflashed to run on the old firmware and do all the same things.
Mhm! Just realize most of those mamba monster 1’s are getting up there in age... so it’s maybe not the best thing to go with in a speed runner nowdays. It’s a lot like old cars. An 85 ford LTD is basically bulletproof, but now that they’re 35 years old, they’re falling apart just because that’s what happens with Father Time.That's good to know ??
Good luck finding one.Guess I know what my next ESC will be for my Limitless.....
Both of those will treat you very well... but jimo, which i totally understand if you want to go with the xlx as it’s very popular now, it’s very overly qualified taking a truck that size to 100mph. If you plan to shoot to 150, than sure... go with the xlx. But the mm2 is a lot cheaper and will get the job done without issue if you don’t feel like spending the $ on an xlx.Can the, " Older stuff is made better'" rule apply!? ? ? ?
Thanks for all the info I'll look at some mm2 or xlx, see what deals I can come across!
Yup! And the 1717 is 4585 (or 87 it’s one of those) and it’s not made anymore. The 1515 came in 2 forms (2650kv) and (2200kv) but they’re also not made SENSORLESS anymore. Edit my apologies, the 2650 is a 1512. Point still stands though. All 15 series sensorless motors besides the 1515b have been discontinued for years. They’ve been out of production for years so it’s basically safe to say, if you see one listed anywhere that’s sensorless, it’s counterfeit and not going to perform well at all, especially at speed. The exception is they still make the 1515B, which is a 2200kv 4274 sized NON-FINNED can, but that’s only sold paired to the sidewinder 8th esc. All the other OEM non counterfeit 1515 castle motors are sensored now. They’re still awesome for going stupid fast, just as well as the old ones, but they’re more expensive.How does Castle size their motors? 1515 2200kv the same can size as a EZRUN 4274 2200kv size? Sorry, never been able to find the explanation online.
Sounds like us lmao
Send some links when you go to purchase... I don’t want you to buy something fake, I know guys who got burned and I don’t want it to happen to anyone else.I went to their website, and like 90% of the stuff is discontinued, or out-of-stock.
Found some new ones on eBay for about $130~$140. Probably should jump on one now.....
If you found some they are probably fakes. There is a lot of fake ones.I went to their website, and like 90% of the stuff is discontinued, or out-of-stock.
