ARRMAgeddon
Unboxing my upgrade electronics for arrma talion
Ill be using the stock pinion for the time being just to see if i need to gear up or downWhat pinion and gears you running
Hi there sir woodieGet that thing installed so we can see how you like it!![]()
CANT WAIT TO HAVE YOUR COMMENT ON THAT!!Unboxing my upgrade electronics for Arrma talion
ok!!Not for a while i have so much more to get
Bearings= fast eddy
Servo==== not sure yet which servo to get
Servo mount
Wing mount
LiPo and charger
Hopefuly i can order some later today
Max8 is kind of small for a 1/7 scale rig. What gearing are you using?i installed this in my limitless and when trying to do a speed run it cuts off at about what i would think the hafl way point is. gps said i got it up to 67. but when it cuts out i lose throttle and brake for a second then while pumping the brake it comes back on. any tips? ive tried multiple battery on both 4s and 6s i tried to turn off the LVC to see if that help
Did you have issues with the blx185/2050kv system?Unboxing my upgrade electronics for arrma talion
