If you have a heatsink, you push air towards it. If you have a radiator, you can pull thru. Moving air in general is always good, but I think pushing towards a motor is the bestAre your fans pushing or pulling air? I got then yeah racing dual fan w heat sink and I’m using the spacers to get max air flow pushing the heat away from the motor.
however I’m thinking for my esc I might want to be pulling air into it to help the capacitors stay cool.
Ok I’m liking that ideaPersonally, I always cut my wires shorter and resolder them, either to the fans or the plug. Keeps them a little bit neater.
Wish we had heatsinks we could set up a push pull setup on.If you have a heatsink, you push air towards it. If you have a radiator, you can pull thru. Moving air in general is always good, but I think pushing towards a motor is the best
