- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
I run a similar setup on my Outcast 6s, last summer after a 2 back to back bash sessions without letting it cool down the max temp I saw was about 145*F outside temp was upper 80s lower 90s.Deos it keep your system cool
They don't thermal on me on a 80F day bashing in grass. My trucks only sit long enough for me to swap a pack.Deos it keep your system cool
Need some fans for my kraton 6s killed the one in my max 6 want to put a bigger 40mm fan in it would i need to put it on top of the sec shroud do not want to remove it
Yeah too bad shipping costs more than the mount does.I use the adapters from Alza Racing, fit perfectly!
https://shop.alza-racing.com/en/universal-parts/96-universal-40mm-fan-mounting-base.html
WFO Racing makes a fan shroud that holds a 40mm fan. I have a 4028 fan on my Kraton but you don't need to run that big of a fan. https://wforccustoms.com/products/max-6-fan-shroud
With my fan guard the screws I used measure 35mm.Hey I got one of these for my Xmaxx to mount a 40mmx28mm fan like yours appears to be. Any idea on screw length needed?
