imasnyper
I'm fairly new to the hobby, I've put about 5 battery packs through on my Kraton 4s. I just ordered some replacements for some lost parts from the last time out with it, and also ordered a Fast Eddy sealed bearing kit at the same time. My question is, should I wait until the stock bearings actually seize before I do the upgrade/replacement, or should I just replace them all right now to avoid the headache of doing it later and possibly breaking other parts in the process? I do run it a lot on gravel, and when the wheel popped off on the last run, the outer wheel bearing puked out on to the gravel and you could see a lot of dust and gunk on it, but it was still spinning fine.
