Thanks for confirming, LHS has sets for brcc but none for senton or granite, I’ll just pay extra and get them. Btw do you know what that extra flanged one is for?I believe that the additonal cost is for the flanged (metal) spur gear bearing and the center driveshaft support bearing dound in the 4s models. Otherwise, the rest of the bearing quantities are the same throughout the 3s/4s fleet.
Ah ok, I’ll just save them for a future 4s conversion or purchase. Thanks for the help ?The flanged bearing is strictly for the 4s metal spur gear. The 3s plastic gear does not use this bearing type.
View attachment 87648View attachment 87647
Avid would mean having to order online and international shipping, I’ll have to settle for the fe for now, but I will double check before installing now.I find it strange that they would include a flanged bearing in the BR3s kit as there is no mention of such a bearing in the exploded view. I bought the same kit a while back and didn’t question it as I needed that bearing to install the 4s slipper unit in my Granite.
FYI: I since changed all my FE bearings for Avid as many FE bearings were dry From the factory.
I need to get the exploded view enlarged or get reading glasses, I see it now it’s part of the slipper assembly.I ended up ordering from another company because it was to muddled to figure out which bearing set from eddy I needed. And my 3s senton has a flanged bearing So it’s not just the 4s line. Part number ARA620003
Looks like that's changed. My 3s Granite 4x4 BLX has a flanged bearing in the plastic spur gear.The flanged bearing is strictly for the 4s metal spur gear. The 3s plastic gear does not use this bearing type.
Same for the Granite, ARA620003And my 3s senton has a flanged bearing So it’s not just the 4s line. Part number ARA620003
The bearing for the BRCC center driveshaft support is the 15x21x5 one. Not flanged. I have one since I installed the center driveshaft support in my Granite.I believe that the additonal cost is for the flanged (metal) spur gear bearing and the center driveshaft support bearing dound in the 4s models. Otherwise, the rest of the bearing quantities are the same throughout the 3s/4s fleet.
My Granite exploded view does show it.I couldn’t say as I sold my 3s slipper assembly to local guy and bought the 4s assembly. If this is the case, Arrma needs exploded views to reflect this revision.
My exploded view did have an error, I actually forget what it was now. Had me scratching my head and double checking myself.Thanks @GRC. That is very bizarre. Arrma needs to get their act together and straighten this out. Good thing they don’t manufacture jet engines or they’d be in deep doodoo.
