I’ve got the Futaba TPV3 transmitter on it. Reverse the throttle did not help, I don’t what other setting you look under. This transmitter has a digital display.You may need to switch the position switch on your controller and then recalibrate the esc. which controller do you have?
I was able calibrate my brake at a higher percentage, so that my reverse was not so sensitive, but I do still think my reverse is stronger than foward. Do you guys have any pointers on punch settings? I know how to adjust to each punch setting, but what is the difference between factory setting at punch 4 to punch 9 setting? Can’t find that info anywhere.Does anybody’s outcast have stronger reverse throttle than forward throttle? My Outcast goes faster in reverse. I don’t know why it does that.View attachment 102245
More Punch ?I was able calibrate my brake at a higher percentage, so that my reverse was not so sensitive, but I do still think my reverse is stronger than foward. Do you guys have any pointers on punch settings? I know how to adjust to each punch setting, but what is the difference between factory setting at punch 4 to punch 9 setting? Can’t find that info anywhere.
If it's a noticeable power difference between forward and reverse I guarantee it setting 5 reverse rotation.punch has nothing to do with making it faster in reverseTry reversing rotation of motor on esc.its the 5th setting. When in take a motor out of 6a car an put it in big rock it does that cause motor sits other direction in 3s trucks.or you can switch 2 of the three wires going to motor around. Not sure what colors to swap around though.
