Going to replace the bearings when the bearings get here on the V4 6s,but I don't see any instructions or videos on the process. Are they and I'm just missing them? Anybody have any instructions they want to share? Tips/tricks?
Is that the liquid? I usually use the stick for other projects. I don't see 242 in a stick form and I'm not sure what the equivalant would be in stick form?I like Blue TL 242 for RC applications you'd use it with. You don't ever want to use it with plastic to plastic, only metal to metal fastening.
I've always used the liquid type. Lil drop on the end of the screw, twist, install and let set for 24hrs and good to go! ?
Not sure if the stick would allow you, to some how apply the TL to the screw first as well? ? Sorry, I've just never used your style of TL.Yeah,since the screws are so small in some instances,using a stick may be difficult.
