FELONY2800
Who can recommend some fast set ups for my typhon? Motor , gearing , esc?
Castle everything. What kind of castle esc are you running or is it just stock? And more so for speed running. I thought about a 2200 but I wanted to know if I can go above thatI'm biased castle all i now
2200 mmx combo 6s 29/46 or 29/40
1650 mmx combo 8s 29/34 or 34/34 I only ran 4s so far hit 78.
But what setup you have now a 3s or 6s typhon
Are you speed running or speed bashing and launching it?
2200 will and can go fast but gearing, good strong lipos is definitely needed, diff fluid is key also I run 100k/spool/60 now. but when I was on 6s I ran 60/500/80 street bash/dirtCastle everything. What kind of castle esc are you running or is it just stock? And more so for speed running. I thought about a 2200 but I wanted to know if I can go above that
Max 6 idk nothing about but same functions I'd assume, 2200 on 16/46 is fast enough on 6s if you not speed running. I bashed with that same gearing awhile back had no problemsI'm thinking about the max6 combo with the 4985 for my Typhon
Is not a Speedrun cars, just a bashing wild beast
No offense but the question was just put out there for opinions to be thrown out there. But it's for speed runs.Not to rag on you or anything but your question is very general.
Fast setups for bashing, speedruns, or drag are very different.
You gotta be more specific.
Dang brotha that joint is super niceIm full 8s now but I run 4s until my eyes catch up with cars I hit 73 mph tho on residential street half ass pulls.
https://www.arrmaforum.com/threads/8s-typhon-update.42304/
Ok ok I get ya I get ya , just trying to get a good set up. I've been tinkering with it , but just now finishing up my infraction so this one is next2200 will and can go fast but gearing, good strong lipos is definitely needed, diff fluid is key also I run 100k/spool/60 now. but when I was on 6s I ran 60/500/80 street bash/dirt
Well on my infraction I have a tp 4070 2250kv motor and a mamba monster x esc.honestly I'd go straight to 8s specially if you're infraction is 6s c'mon order one its ok you can do it we will be waiting
That's what your currently running?160amp Spektrum ESC, and 1250kv Spektrum motor with 27/34 gearing on 8S.
Oh trust I can drive it lol. Is that what your running?XLX2, TP5650 1720kv, GP5 Diffs, 30T pinion, 34T Spool, 100mm Foams, 2x4S lipos
Should be good for 150mph. If you can drive it.
And your talking about having gp5 diffs for the front and rear diff and replacing the center with a spool correct?XLX2, TP5650 1720kv, GP5 Diffs, 30T pinion, 34T Spool, 100mm Foams, 2x4S lipos
That setup would get you just shy of 90mphThat's what your currently running?
damn doc you trying to send marty back to the 50s with that setupXLX2, TP5650 1720kv, GP5 Diffs, 30T pinion, 34T Spool, 100mm Foams, 2x4S lipos
He said fastest I assumed he had a road that held beyond 88mphdamn doc you trying to send marty back to the 50s with that setup
I do I'm out in Carson, California and it's some good clean road in the industrial areasHe said fastest I assumed he had a road that held beyond 88mph
Doc has spoken have fun marty
Get those motor leads covered up ️I use to run the K8 electronics but I’m trying something different now.
XLX2, TP4070cm, and 6S LiPo batteries.
