- Massachusetts USA 🇺🇸
- Limitless
- Kraton EXB
- Typhon 3s
- Typhon 6s
I don’t think a lot of the mentioned setups will fit in a stock typhon just my opinion lol, but fast set ups for sure.
You may be surprised what you can stuff in that little Typhon. Although there is always "stretched chassis" options to give more wheelbase and better stability at high speed.I don’t think a lot of the mentioned setups will fit in a stock typhon just my opinion lol, but fast set ups for sure.
What spool to spur ratio you using?I use to run the K8 electronics but I’m trying something different now.
XLX2, TP4070cm, and 6S LiPo batteries.
Lmao , so it started off as talking a typhon than I mentioned my infraction and that's where it went left lmao.I don’t think a lot of the mentioned setups will fit in a stock typhon just my opinion lol, but fast set ups for sure.
Pinion n spool size if you don't mine sharing?You may be surprised what you can stuff in that little Typhon. Although there is always "stretched chassis" options to give more wheelbase and better stability at high speed.
Leopard 5692 (1340kv) with the PPS motor mount.
Never tested it, but I had installed a 29T spur and 54t pinion which is waaaay to much gear.What spool to spur ratio you using?
Lol I was about to say. That'd a pretty big pinion lmaoNever tested it, but I had installed a 29T spur and 54t pinion which is waaaay to much gear.
You said you wanted the fastestLol I was about to say. That'd a pretty big pinion lmao
That gearing would put it near 200mph LOL
DOOOO ITTTTT LOLYou said you wanted the fastest
im running 2200 kv 4s out of axial ryft and 26 tooth pinion it catches air when it wheelies it slaps the spoiler down so hardWho can recommend some fast set ups for my typhon? Motor , gearing , esc?
Nice , you have a pic of the set up?im running 2200 kv 4s out of axial ryft and 26 tooth pinion it catches air when it wheelies it slaps the spoiler down so hard
