Stack15
- Macon, Georgia
- Fury
- Granite
- Mojave
- Talion
- Voltage
- 4x4-Mega
Okay. So I put a new ESC on my Fazon Voltage. That required me to also change the steering servo. This is because the stock ADS5 servo has a five wire connector and my replacement receiver only accepts three wire connectors.
So I obtained a 3 wire ADS5 on eBay. I also have in my possession a Savox SW0230MG that is supposed to go on my grainte 4x4.
I put the 3 wire ADS5 on the voltage and it worked for awhile. It was a weird fit as what I believe is called the “servo saver” from the stock ADS5 would NOT fit the other ADS5. So I used a circular one that came with the Savox.
But anytime I would lightly tap something, the front wheels would cease. I got frustrated and removed that servo. Now I am thinking that I need a different servo saver and a new “rocker arm connector doo-hickey” (really don’t have a name for that part but the servo saver goes into it.
What doo-hickey will fit the standard 3 wire ADS5? Note I also bought two ADS15s. They aren’t here yet but I am thinking I will probably break the ADS5 with all these installs and uninstalls.
Also, I already have some advice from JerryRigged (he’s my new hero) from a different thread... as follows:
The truck is "Compatible" with any servo that fits. If the servo saver does not fit, then you need a new servo saver. Kembrough is the gold standard, and are under $10. I'd look at either the Mid size or the Large size. Move the two ball studs over to the new SS, and use the correct insert for your servo (Arrma Servos are 25t spline, so use the "F" insert - Futaba is also 25t)
Large-
https://www.amainhobbies.com/kimbro...ver-universal-spline-connector-1-kim124/p4584
Mid-
https://www.amainhobbies.com/kimbrough-mid-size-servo-saver-futaba-hitec-airtronics-kim201/p32168
Or you can go with a metal gear servo, and get rid of the SS all together.
Large-
Mid-
