Mr.Duke
Moderator
Community Leader
ArrmaForum Fan
- NC
- Infraction
- Limitless
- Kraton 6s
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
I’ve been toying with the idea of using the front and rear tires and diffs from the Felony on a speed runner but the math just doesn’t add up for wheel speed front to rear.
Front tires are 100mm diameter
Rear tires are 107mm diameter
Front diff uses 2.8 ratio (15t pinion / 42t crown)
Rear diff uses 3.214 ratio (14t pinion / 45t crown)
No matter how many times I run the numbers the front tires are always spinning faster than the rear tires.
Example:
Stock Felony with stock 16t pinion installed 46t spur
2050kv (6s)
front tire speed = 67.11mph
rear tire speed = 62.56mph
* 4.55mph difference
26t pinion 46t spur
front tire speed = 109.05mph
rear tire speed = 101.66mph
* 7.39mph difference
27t pinion 34t spool
front tire speed = 127.68mph
rear tire speed = 119.02mph
* 8.66mph difference
Let’s say you want to go crazy and run a TP4070 2700kv with 30/34 gearing (6s)
No load - no drag- no voltage sag
front tire speed
Rear tire speed
Example:
2050kv (6s)
26t pinion 46t spur
front tire speed
Rear tire speed
