Mr.Vylan
If you're in control, you're not going fast enough
- Bay Area, California
- Felony
- Kraton 6s
- Senton 6s
- Senton 3s
Although there are several threads on this topic I can't seem to locate the following question.
QUESTION: Without changing the diff to accommodate a different rear wheel size. Is there an option outside of the Hoons stock wheel?
I'm not concerned about the compound. I simply want to know if there are other manufacturers out there offering a 1/7 or 1/8 wheel option that meets the height size.
Tire: width: 53mm - height: 107mm
Follow up question:
If there are options for the correct height, do I need to be concerned with the tire width?
Does GRP offer a 107mm tire?
https://www.grpgandini.it/tyres/1-8-gt/t01-revo.html
- Inner Wheel bead diameter: 3.27" (83mm)
- Outer Wheel bead diameter: 2.95" (75mm)
Follow up question:
