- Felony
So far I'm really liking the Felony. Good runtime with 5000mAh 6s (outlasted a 3s Typhon and a NiMH Rustler) and an all around fun car to drive. Though I have three complaints about it that I'm unsuccessful tuning out:
- High speed steering is sluggish. Wow. I was really surprised about how bad this car turns. Throttle steering works well but when you start getting speed... forget it.
- Throttle of course induces a ton of oversteer. This is not what I'm trying to fix. This concerns normal steering without inducing throttle oversteer.
- At first I thought it was severe understeer so I tuned the suspension with a stiffer rear sway bar and rear springs. It helped but not nearly as much as I hoped.
- It still looks like it now has a ton of high speed understeer but the behavior has some oversteer at low speeds (it is really touchy at low speed.
- I cannot lay the front shock down any further but the back I can stand up one more tick. I'm also wondering if standing up the rear shock will double the benefit since it has a stiffer spring as well.
- I'm also not completely sure if the compound is too hard. Running the stock tires still.
- Stopping power is abysmal. This car stops like a slug. Even with 100% brakes on the ESC, this car seems like it is way to heavy for the stopping power it has.
- Honestly I'm not really sure how to fix this since this uses engine braking vs caliper braking. The only thing I could think of is stiffen up the front springs to reduce dive. This won't be a huge improvement but all I could think of.
- If a stiffer suspension is the answer, this contradicts what I'm doing for understeer.
- Also goes back to tire compound being too hard.
- Car will automatically do a 180 when going in reverse. This is a weird one. When you reverse the Felony, the wheels will suddenly turn to the left and cause the car to do a 180. This is without any user input to the steering wheel.
- I tried this multiple times. It always will steer itself and it will turn the wheels left. With very little effort, the car will do a 180 really quickly.
- Is this an AVS thing? I have never seen this behavior before.
