Omerta
Hey Everyone, Few upgrades plan on doing in the next week or 2. Also some new tools and parts.
GKA 1 piece (tall) aluminum servo mount
MIP metric driver set
Stainless steel screw kit
Plaig premium v2 bearing kit
RPM wing mounts.
Power HD glitch buster.
Few questions that need help with please.
which diff fluids to go thinking just stock standard again 10k/100k/10k.
Not sure on steering servo DS3218 or power HD 25kg low voltage servo.
Which brand for front/back chassis support braces.
Not sure if should do BEC mod.
Not sure if should get RPM front/rear A arms.
Also can't seem to find front diff housing replacements as I have stripped the bottom part where the hinge pins go in and the 2 screws. Also bent a front drive shaft.
Any input / help and links appreciated. Thank You
RPM wing mounts.
