Omerta
after a few weeks of owning a kraton I have finally broken the stock servo.
any suggestions on a good upgraded servo / servo mount.
been looking at the EcoPower WP120T or JX Servo CLS-HV7332MG
not sure whether to get the Voltage Hobbies servo mount with the clamps or find a one piece?
also:
bent front right drive shaft
destroyed front diff case where the screws go in & bent the screws.
bent front hinge / pins going into a-arms
loose top right pivot ball / wheel can't seem to fix it when tightened all way.
bent wing / wing mount
bent stock front bar / typhoon t-bone bar.
chewed up the front input shaft cups & a bit of the a arms but still drives fine besides veering off to the right.
front part of the shell corners from bottom of windscreen cracked and is about to snap the front off even after 2-3 layers of gorilla tape.
all of the above happened after 1hr+ / x4 batteries 2 days in a row also due to being trigger happy first time doing front flips and back flips sending it as high as possible doing double flips abusing the hell out of it and yeah 4-6 bad landings / cart wheels later surprised its nothing major or crazy breakages.
also:
