chazekxt46
- Granite
- Raider
- Senton 3s
I run typhon 3s arms to but the ft is a little wider then the rear
Yepwould this trx pinion be okay? I can't find any arrma 18 tooth pinion nearby...is currently out of stock ?
For a stock Arrma BLX motor and spur gear, yes that will work.would this trx pinion be okay? I can't find any arrma 18 tooth pinion nearby...is currently out of stock ?
Make sure you throw a little loctite on the 17mm wheel nuts as I lost mine in the bush last week. Wheel went flying and I couldn't find the nut anymore...
Did you need longer driveshafts or no?What turnbuckles did you go with? I'm kind of excited to get this done myself and have all the other parts in my cart on Amazon. I'm assuming the typhon turnbuckles?
No the driveshafts are the same between all the Mega and 3S models. Just know there is a front and rear set tho.Did you need longer driveshafts or no?
Ok thanksNo the driveshafts are the same between all the Mega and 3S models. Just know there is a front and rear set tho.
