Kraton Finally ready!!!
Cereal_killer
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
Hr mount installed. Downside. 22 or 23 pinion max! Ordering pps mount... the 1250kv was too heavy for the factory mount.. hopefully quits eating through spurs! Diff covers finally on! Along with many other things that are done finally. Can't wait to at least get a run!
Nice I just got one them fans u got on ur esc. I am trying to put on my motor. But it hits the body. So I got fiuger out new way to mount it. And with a 2 or 3s battery it moves some air. And you will love the PPS mount. 👊 Nice rig
I think 22-23 is about all the stock v4 mount will take too. You can drop to a 46t spur and fit a taller pinion as well.
I have the v5. With one screw. I could go up to 30t. But it was eating the pinions because it wasn't aline right.. but 25t was the max with two screws. Plus I'm running the 8s system. Pps will take care of it. Just temporary
I run 24/46 on the stock v4 mount which should be just like the v5 and there is room to go up from there. My 8s dual battery stretched mojave uses an ebay special that as the mount slides out it angles up. i am running 38/50 on it :ROFLMAO:
Jeez 38/50!!! Wouldn’t it be easier to find a smaller spur 🤣🤣🤘🏻🤘🏻
what tires are those?
what tires?
