- Bozeman, MT
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Nero
- Raider
- Senton 3s
- Talion
- Typhon 6s
- Vorteks
What are your thoughts on combining a low-KV motor with a Neu planetary shaft transmission to greatly increase RPM before hitting the primary gearing?As @ABabyEater mentioned its a torque difference as to why. Remember we are comparing a 180mph motor vs a 190mph motor. That is around a 5% difference.
There was mention of Neu motors. The issue is that they only really have good options for 40mm motors. Their motors are more efficient and tent to net about a 2-5% increase in output. Their larger motors are not made for high rpm use.
For now the 56mm and 58mm diameter motors from TP Power seem to be the best. I still don't know what motor James had in his top speed car. It was all black and did not have the same end caps as TP Power.
If you are going to spend money on a motor, for now I would say focus on the TP 1/5 scale motors and shop in the 1100-1400kv range. Unless you have a big budget and want to try the MGM & Lehner combo.
