Wondering why you chose the 1520 over the 1717, as the 1717 would fit easier and has the same performance? Also curious which BSR foams you chose to run.Mmx8s
Castle 1520/1650kv
40t spur
24r pinion
BSR foams
Bittydesign body
1520 has a bit less torque but gets up to rpm a bit faster.Wondering why you chose the 1520 over the 1717, as the 1717 would fit easier and has the same performance? Also curious which BSR foams you chose to run.
Isn’t torque required to gain RPM? Castle states they have the same performance so that’s why I was wondering.1520 has a bit less torque but gets up to rpm a bit faster.
BSRs are XX Pink.
Technically yes, but because these motors are already blowing the tires off it’s better to take the lower torque in my case.Isn’t torque required to gain RPM? Castle states they have the same performance so that’s why I was wondering.
