I almost got done tonight. Another hour this week I’ll be done
Like this?You need some little plastic clear trays in various sizes so you can group parts with their screws IMO. It also helps keep your work area cleaner if you can put stuff in small trays, then put all those little trays you don't need into a big cardboard box or plastic tub.
I have a few magnetic trays and a small container with 7 different plastic trays in it but I need more and am thinking about ordering a bulk set of something like this from Amazon:
Mad scientist style! Lol. That’s a combination of Limitless and Fireteam parts. Not sure if you can see the different diffs and shims for both models in there. I’m simultaneously building both from the ground up, down to the LSD diffs for the FT, quite fun!@joshjosh ....., that makes things interesting if nothing else.
Thanks I’ve actually forgotten all about themThe manual/ exploded views are your friend
Very niceI almost got done tonight. Another hour this week I’ll be done View attachment 274542View attachment 274543View attachment 274545
Very nice. Wish that I could say the sameI almost got done tonight. Another hour this week I’ll be done View attachment 274542View attachment 274543View attachment 274545
me and you are doing it exactly the same way…lolLike this?View attachment 274577
Marked and noted lol triple bearing sweeeetI would go ahead and try to fit that front M2C brace, I've had fitment issues with mine.
Also, I see you went with the M2C front upper hinge pin holder. I would instead recommend to go with the Arrma EXB front upper hinge pin holder. It's a very good design, good price, and looks beefier than the M2C model which only works with the smaller RTR version hinge pins. EXB Front Upper Hinge Pin
I also had some slight issues getting the M2C front and rear lower hinge pin carriers to fit. Where it mounts between the differential carrier and the chassis it's slightly off. My differential carriers are also aftermarket (ScorchedRC), so I haven't pinpointed where the issue is yet, but I plan on swapping some parts back out to see. I was able to force it in, but it sure felt like I was going to snap those screws.
If you're already swapping out the hubs, why not go for the Kraton hubs? You'll only need to add on the wheel axles, and then I'd recommend the triple bearing t7075 model from Treal
Rear Treal hub
Front Treal Knuckle
