- SE MICHIGAN
- Granite
- Infraction
- Outcast 4s
- Typhon 3s
- Typhon 6s
Esc came from a used car from the classifieds here... it powers up fine, has forward and reverse, the fan works, and it will calibrate fine, but it will not go past entering program mode to change settings. I don't believe it's the power button, as the set button does work to get it to enter programming mode initially, but after that, I can't get it to pick the first menu item. It might work if you had a Spektrum programmer, but I don't know for sure and I don't have one to try it. Like I said, otherwise the esc works as it should, feels like it's probably stuck in default settings as the punch and brakes are a little soft, at least for my liking. $50 shipped, it's still in the car and I can take a pic if needed
