DaSL0WNESS
Anyone tried running a Firma 150 esc on 7s before?
Or better. A castle mmx8s. Automatic detection of 7s. No need to turn off LVC or do anything.6s max on the Firma 150a, you would need the Firma 160a, turn off LVC and run an external lipo alarm to run 7s.
You can use telemetry with low voltage alarm on the radio as a nice option to a lipo alarm. Like for example radiolink rc6gs. The new v3 now remembers the adjustable voltage alarm setting for each model.
v2 used the same setting for all models. The previous receiver did not support more than 6s either. However, an easy workaround would be to only have the voltage sensor to one of the two battery connectors. If you always use the 3s battery on that one (assuming use of two batteries) then no changes would have to be made. That is what I do/did. Mainly because my 4s battery had more mah.
No. Im talking about the "Voltage telemetry cable". The R7FG receiver have the capability to read voltage directly from the battery if its connected like in the picture below (or have the two wires soldered directly to your ESC battery connector like I do). It will send a live voltage reading to the radio and you can see it on the display. Low voltage alarm can be set on the radio.Guessing you're talking about first generation radiolink stuff. I run a rc4gs v2 with the r6fg reciever and had no issues with my 160/1250 setup on 8s.
I don't intend on trying it as i don't have matching 3s and 4s mah packs anyway was just curious if it was possible in my quest of maxing out the 150/2050 setup for 132ft.
