sonicslp
- Granite
I unboxed it yesterday, went over everything and took it out today for about 30 minutes. First, I'm impressed. This might be the best $300 bargain on the market right now, imho. I come from crawling (mostly TRX4-stuff), so this is fairly new to me, so I have a couple questions, excuse the newby:
1- Are the bearings sealed? How well does this thing do in sand/water? I know it's considered a "basher", but I just don't know how confident I should feel in fine dirt/sand/water scenarios. After all, it was only $300. If not, is there a bearing pack that you could recommend? I'd just like to bite that potential problem in the butt right away.
2- Steering is quite slow. After a bit of youtube'ing, I see the servo+transmitter combo don't have a great reputation. I do have an extra 20kg servo and plenty of receivers that I could swap in there to connect up to my own transmitter. I assume this would be the recommended route? Are there any gotchas I should know about when swapping out these items? I assume the stock servo has a saver, so that may be an issue depending on the type of servo I have.
3- ESC/Battery issue. FYI, I put in two different 3s/60c/5200mAh batteries (both balanced and performing well in TRX4) and within five minutes of fairly fast blasts over wet grass (in the park) it would go into limp mode. After sitting for a few minutes and reset, it would work again. Do you think this is an over-heating issue? Battery was not warm at all, motor was only a little warm, wires were fine. Not sure what temp the esc was at, though.
4- Is it recommended to do a 4s build on these? I'm already impressed with what it does on 3s, but it would be fun to do a 4s build.
Again, sorry for the newb questions, thanks in advance!
