Finally servicing my diffs and replacing bearings with sealed. This is my first Arrma and my first time opening up a diff. I watched a bunch of YouTube videos on it and got various shims but not everything I need. Looking for advice.
Rear diff has a shattered pin on the crown side. Both out drive shafts are damaged and won’t pull out of the cup and the ring. Gears all look Ok though.
I need diff pins. Should I get new out drives too? They look fine they just won’t come out. Should I set up a jig and tap the out drive shafts out? I have a bunch of different shims but not ones that sit under the pins. Should I get extra shims for under the pins to tighten it a bit, or extra shims for behind the planetary gears? Or both?
