First Limitless build
Ok good to know., I have the HR braces and have filed the crap out of them and dremelled
As well , do you feel ther
As well , do you feel there’s no issues with chassis flex? Thanks man
I have no issues.... I don't just speed run the thing. I beat the hell out of it on a track as well.
Word of advice on initial setups. (you likely know this with the XO-1 and GTP2e experience). Stiffen the rear spring pre-load as much as you can.
Use shock travel limiters and can use droop screws also to ensure travel limits exist. You want some rake in the suspension to ensure the rear is higher than the front.
If that ride angle is kept good, then blow-overs should be eliminated.
Trimming down the rear wing to the first line is a good idea also.
You have an example of your setup with shock limiters?
