ARRMAed & Dangerous
Ok so I finally took her out and wow, Amazing! Found a great spot at local park with two lit up empty baseball fields with a raised walkway between them.
Decided to see if I could clear the walkway jump...unexpectedly launched was more than I expected... started to flip so I then throttled a bit and over corrected... landed upside down on its hood, bounced, rolled, & kept going. Not a thing borke...we later measured the divit where it landed & not even on full throttle, stock 12T pinion...it cleared 52 feet. Could not believe it.
Unfortunately nephew drove it and accidentally nosed it into a sprinkler lid that was popped up. Only thing broke was the connector attaching the front left shock to the a arm.
I know the v4 shocks are shimmed, so am hoping I can find just the connector at LHS & not replace the whole shock. I've found them online but still try to get one today.
The video is off because phone died so mo the whole time and the field lights were led so a lot of flickering.
